Need to compare a heads and cam ve table to mine
I just want to get a feel to see if mine is going in the right direction.
Got efi live and it's 10.5to1 in light throttle and off throttle areas. I adjusted around those cells and there at high 30 low 40s. Was wondering if that is normal with heads and cam with 9.2to 1 compression
This is a ls1 with 317 head, 80lb injectors and brute speed blower cam
