P0336 Crankshaft B+ code
Old 05-25-2014, 07:06 PM
LS1-450's Avatar
Default P0336 Crankshaft B+ code
Down to it being the PCM. Checked sensor & it has similar resistance to a known working sensor. 1/3rd of the way through visually inspecting reluctor wheel. Wiring is OK. Sensor measured similarly through wiring as it does @ sensor.
Have been chasing a sudden rich/un-burnt fuel issue @ first blip of the throttle. Could never tune it out. Finally, it threw a code. Think the damage to the PCM happened when swapping heads over Winter. Blew the engine fuse while moving some wiring.
Anything I've missed? Am ordering a re-built PCM on the 28th.
Quick Reply: P0336 Crankshaft B+ code
