Symptoms of wideband going bad?
I have a PLX wideband that ive put about 20k on since I got it..
The strange thing is its been dead on until yesterday
I drove to work yesterday and it was dead on.. Drove home and it was reading 11.7 at WOT!! Im usually 12.8 or so..
Would the sensor going bad cause it to show a full point rich?
My car seems to be running fine and I havent changed anything recently..
I recently got launch control in my car, could all the unburned fuel from the launch control being active ruin the sensor?
At cruise and idle the sensor seems to be running the same as it always has..
Im lost at this guys, what do you think??
Moderator
The fail mode I've seen is, reading gets jacked way lean.
Not to say there couldn't be others.
Sure you've got things like COT turned off? There are
some fueling modes that will override the normal AFR.
Sensor doesn't read fuel, it reads oxygen and does
some hokey math to get an AFR or EQ number from
that.
Knowing what the commanded AFR at the time was,
and how commanded usually relates to delivered, would
be useful.
that.
be useful.
I feel like an idiot guys. I did a free air test and it passed with flying colors (my unit is self calibrating) While I was poking around my motor trying to find the problem I noticed my intake boot before the maf was loose so I pulled it apart and found a piece of electrical tape stuck to my maf. I feel like my car gained 30 hp lol.. Runs great and now my gauge is dead on again!
Glad you got it figured out. I do have a question though. Would a loose wideband sensor that I have screwed into the bung port cause lean readings? I've been having really bad lean readings, especially at idle and cruising speeds. Last night I checked were I have the sensor screwed into the bung and it was way loose. Would that cause lean readings?
I would think that it very well could.. I wonder if there is some kind of vacuum in the exhaust at cruise causing it to suck in outside air.. just an idea but being that the leak is at the sensor itself I would definitely say it could.. I know that my wideband reads about .2 too lean all the time because my sensor is in one of my rear o2 bungs that I wasnt using..
Yeah I mean if your car seems to be running ok still then it must be something with the wideband.. Mine was surging like crazy when that piece of tape was stuck on the maf so if yours isnt doing anything out of the ordinary I would bet it was cause it was loose
there is an easy test for a wideband o2 sensor
take the thing out, turn on your wideband....
it should read free air(or its highest value)
then take a rag, and spray some brake cleaner in it...
wrap it around the o2 sensor
the AFR should creep richer and richer....(it should stay rich until all the brake cleaner evaporates)
if at some point it suddenly shoots up to free air again, then the sensor is toast
if it stays rich, then it is ok.
its a well proven test, and you can see it on videos on youtube if you need to see it visually to verify your results
it reads oxygen content, not fuel content
I'm not certain a rag with gasoline would work....the combustion process is what breaks down the gasoline to allow the O2 sensor to detect left over oxygen
the brake cleaner breaks down immediately upon contact with the air and the sensor can see the left over oxygen
The brake-cleaner-rag test: the evaporating brake cleaner displaces any air (oxygen) in between the rag and the wideband sensor, this causes the wideband to show rich (the brake cleaner does not ignite, it evaporates).
Gasoline does the same thing, except it does not evaporate as quickly as brake cleaner... but be careful, gasoline vapor ignites very easily, don't get burned.
