need help with gauge cluster wiring on '94z
Hope you guy can help because so far none of it makes sense. Im trying to wire up the gauge cluster in my '94z to work with my ls swap harness. I have the 3 signal wires coming off the harness just hanging there but cant not figure out for the life of me what wires on the cluster to hook them to.
Iv seen all the diagrams on SHBox, Haynes, etc but the colors and/or pin cavity on my plug doesnt match up. I need power, ground, volts, speedo, tach and temp sensor to work on my cluster. The '95 pin-out doesn't match my '94. All the pinouts i see it shows as if i should have like 26 wires coming out of the pigtail and mine only has 11. Do you know what color/cavity on a '94 cluster are those 6 sensors i need?
Heres a pic of my pigtail coming out of my cluster.....
