C5 ECM same as F-body?
Old 05-31-2014, 07:37 PM
partemisio's Avatar
Default C5 ECM same as F-body?
I have a 240sx lq4 swap that I'm working on. I just bought an older AEM plug and play stand alone to use for tuning. I'm wanting to know if I can plug this ecm into a c5 to make sure the ecm is good cause my car won't be finished for a few weeks? The paperwork says it works on 99 and up camaro and trans am but says nothing about corvettes.
Old 05-31-2014, 09:19 PM
2xLS1's Avatar
It depends on what vehicle and OS it is programmed with. Vetes and F-bodies share the same hardware (service number) PCMs but they are programmed different.
Old 06-01-2014, 05:37 AM
partemisio's Avatar
So would it be safe to plug this one in? I guess the biggest thing is that the pinout is the same. I just need to be able to read the injectors and what not, I'm not gonna attempt to start the car or anything.
Old 06-01-2014, 09:13 AM
gofastwclass's Avatar
Corvettes have three different controllers and all are wired a bit differently.
  • The 1997 / 1998 cars used one.
  • 1999 through 2002 cars used a second (the infamous "411" P01) controller with red and blue connectors
  • 2003 and 2004 cars used a similar looking (P59) controller with blue and green connectors.
The 1997 / 1998 PCMs are the oddballs and look different, the rest have more support.
Old 06-01-2014, 11:05 AM
2xLS1's Avatar
That is mostly correct except the 99-00s use the 09354896 PCMs. Still a blue/red connector PCM. 01-03 Vettes use the 0411 PCMs like the 01-02 F-bodies and the 04 Vettes use the blue/green connector PCM. All the blue/red connector 99-03 PCMs pinout the same.
Old 06-01-2014, 11:57 AM
True. Sorry for the confusion, I meant 411 style red / blue connectors.
Old 06-10-2014, 08:49 AM
ramairetransam's Avatar
what does a 99-00 fbody come with then a 411 or 896?
Old 06-10-2014, 10:47 AM
2xLS1's Avatar
896..
Old 06-10-2014, 11:45 AM
codyvette's Avatar
896 will take o.s. from 411PCM same physical computer.
Quick Reply: C5 ECM same as F-body?
