Misfire cause timing dip without knock count?
Old 06-13-2014, 08:15 PM
abrown0788's Avatar
Default Misfire cause timing dip without knock count?
Working at the dealership I've never looked at timing while diagnosing misfires. Will an engine misfire change the spark advance without seeing knock count? Even if its not picked up as a misfire count on a tech2?
My lc-1 failed twice and ran like crap for a little bit so I pulled over and stuck the factory o2 back in. Now I've notice an intermittent hesitation while cruising. While logging I seen its pulling 14* timing about every 4 seconds with a dip. Is this a pcm response to the misfire/drag?
I even swapped back to my old map with Maf and still does the same thing.
Plugs in it now are the old acdelco 41-985. Swapping to tr6 tomorrow.
Lq4/243/228r112lsa.
Old 06-16-2014, 08:08 PM
joecar's Avatar
I think it's the changing airmass condition that caused the misfire to also cause the timing to change.
( your pic is too small to view )
Old 06-17-2014, 12:38 AM
LS1Tech Sponsor
COSPEED2's Avatar
or burst knock.....
Old 06-17-2014, 01:24 AM
MontecarloDrag's Avatar
Misfires don't change commanded advance.
Even if not picked by the pcm, any misfire will cause a very lean spike. If the afr stays the same then it's not a misfire
Quick Reply: Misfire cause timing dip without knock count?
