elm327 bluetooth scan help!
Old 07-23-2014, 11:43 AM
Fst_Byrd's Avatar
Default elm327 bluetooth scan help!
so I just got a Vgate elm327 Bluetooth scanner and downloaded the android app "Torque".
It will connect via Bluetooth but cannot connect to the ecm of my 1999 trans am.
I've tried the auto scan for protocol as well as the SAE J1850 jpw.
Anyone ever have this issue? I got it linked to my 2013 dodge dart immediately but been trying the TA nonstop and always said it can't talk to the ECM.
THANKS FOR ANY IDEAS.
Old 07-23-2014, 04:24 PM
aknovaman's Avatar
Do any of the lights come on when you plug in the elm 327 device? You may have a blown fuse. Did you turn on the phone Bluetooth and pair with the device?
Old 07-23-2014, 05:43 PM
old93camaro's Avatar
i take it you have a android phone, have you tired starting the car and trying to get it to pair. dodges are bad with any aftermarket hard/software, good luck
Old 07-24-2014, 11:25 PM
truckdoug's Avatar
I've had two of them die for no reason, maybe try another?
at $12 they're pretty much disposable.
Old 07-27-2014, 09:59 AM
Fst_Byrd's Avatar
Yeah it can sync through Bluetooth but not to the ECM. It ONLY works on my dart not my Trans Am.
I've talked to the company and they have sent out a new one for free. Ill update if this one works or not.
I was just curious of theres a certain protocol that's is used for the ls1 or possibly when I had my mail order tune he locked my ecm?
Thanks for the ideas ya'll
Old 07-27-2014, 10:01 PM
aknovaman's Avatar
Locking the PCM file has nothing to do with the ability to read the data stream from the PCM.
Old 07-28-2014, 12:15 PM
Fst_Byrd's Avatar
Well alright than. Learn something new everyday.
Thanks for the heads up
Old 08-10-2014, 11:49 PM
LLLosingit's Avatar
I found my issue to be related to my android phone. The elm327 would work on my Sons car with my android phone and my Son used his phone with my elm327 and it worked on his car and my vehicle but my phone would not connect to my vehicle. I uninstalled and reinstalled Torque and it works fine now.
Old 08-21-2015, 01:35 PM
fst100's Avatar
*bump an dead thread. i have the same issue where it works on my JK Wrangler but wont connect to my 01 camaro via the vgate.
Old 04-03-2017, 11:38 PM
Need4Camaro's Avatar
Likewise.. I'm going to try to uninstall / reinstall and see if that helps. I have tried two different Android devices, both of them successfully pair with the ELM 327 but both get an error when trying to talk to the ECU.
Quick Reply: elm327 bluetooth scan help!
