no spark
Old 07-29-2014, 12:14 AM
hot98z28's Avatar
Default no spark
98 camaro suddenly wont start, no spark at the coils, could it be the ecu?
Old 07-29-2014, 05:04 AM
sicksspeed's Avatar
Need to do more diagnosis. Does it have injector signal, Do you have live data scanner. Is it a Volvo? Sure it could be the e.c.u. but you are going for the throat. We don't even know the vehicle.
Old 07-29-2014, 05:06 AM
sicksspeed's Avatar
Oh sorry 98 camaro. Lol not awake . Still need to diag. more.
Old 07-29-2014, 10:08 PM
hot98z28's Avatar
Bolt ons, ls6, intake, catless y pipe, its getting fuel to the rails I haven't checked pulse to the injectors, it threw a map sensor code but got it fixed, I've ran the car with my Diablo tuner for live data everything seem ok I don't get any rpm reading tho
Old 07-30-2014, 04:57 AM
sicksspeed's Avatar
No rpm I would be leaning toward the crank sensor circuit or the sensor itself.
Old 07-30-2014, 12:42 PM
hot98z28's Avatar
How can I repair the crank sensor circuit or where is it located? Is it hard to change the crank sensor?
Old 07-30-2014, 12:43 PM
hot98z28's Avatar
The live data should read cranking rpm rig?ht
Old 08-01-2014, 06:26 PM
hot98z28's Avatar
Am I in the wrong forum? Second time I ask about this no reply. I changed the crank position sensor and still no fire
Old 08-02-2014, 01:20 PM
Joe1967ls's Avatar
have you checked for voltage while cranking? could be a bad ignition switch, just throwing out and idea
Old 08-02-2014, 10:35 PM
JetMech442's Avatar
Any codes? Did you do any recent mods to the car...Any thing at all ?
Old 08-02-2014, 11:14 PM
hot98z28's Avatar
Ls6 intake im not getting codes i had map sensor low voltage for a while cuz i ripped the
wires while removing the old intake, but fixed it and went away
Old 08-02-2014, 11:15 PM
hot98z28's Avatar
The car started right up the 1st time took it for a ride but when i got back home
it wouldnt start anymore
Old 08-17-2014, 12:50 AM
hot98z28's Avatar
Talking problem solved
I decided to change cam position sensor, before messing with ecu
and found the wires to cps crimped when i swapped to ls6 intake so took them apart and waraped them up, reinstalled everything and bam it fired right up. Thanks for your time in trying to help me figure it out.
Quick Reply: no spark
