Best 42LB Injectors for Driveability/ Easiest to Tune?
Hey all, I'm considering using a set of GM OEM LS3 injectors with the FIC (Fuel Injector Connection) extenders for my heads/ cam build.
FIC also recommended the new Siemens 42lb injectors.
What about the new Bosch Gen III skinny 42lb injectors, that already come with an EV1 plug and need no adapters at all?
Same, I use the GTP injectors as well. They are stated as 36lb injectors but the GTP uses a lower fuel pressure. On LS 58psi rails it equates to 42lbs. As far as tuning. I literally had to copy just one table to my tune from the GTP tune. That's it, you can find info on HPTuners forum on what table that is and what values to add. No other fuel injector tuning needed.
Can't get any easier.
You can get them from the junkyard, eBay, the classifieds, or new from GM (they sell them individually and just buy 8). I bought mine new off the classifieds, then sent them to RC Engineering for cleaning and flowmatching. Well worth it to have an injector that is easy to tune, and plugs right into the factory connector.
i have ls3's on mine got them with low miles for 100 bucks. i then just used DSTECK's ls3/ls7 data from hptuers forum which converts it to ls1 format and pasted that into the tune and she purrs like a kitten
