Someone want to share their timing map?
Hey all...
looking for some examples of timing maps. My motor is an LS1, .020 over, 10.25:1 compression, mild head porting, 575/574 int/exh total lift, 228/228 duration cam, with a 112 centerline. 39 lb injectors, MS3 ECU.
I was chasing an issue that turned out to be MAT related, and kept trying to equalize cells in the area of idle to keep it from wobbling and oscillating all over the place. Turns out that the IAT is heatsoaking, and I just had to adjust the scaling on the IAT/ MAT correction.
So now I am ready to get on to some fine tuning, and want to see what some of y'all are running for timing. Thanks.
