High idle rpm help.....
Ok so I finally got everything set up and fired up my swap. A little about my swap...
LS6/4L60E
230/230 588/595 @ 114 comp cam
Edlebrock vic jr intake, accufab throttle body, Pontiac GTP injectors.
I sent the computer to Brendan at lt1swap.com, I will call him tomorrow.
It should be a speed density tune, so not sure if this may have some to do with the high idle..... I still need to get it tuned so thinking maybe it is in the tune just not really sure.
Problem is when I start the car it goes to 3000 rpm and sometimes goes down to 2500 rpm.
I checked all vacuum lines and they are good,
Is there anything else that I may need to try.
Thanks,
Tim.
LS6/4L60E
Thanks,
Tim.
