tcs light and throttle pedal
Old 08-23-2014, 06:02 PM
ovaboost's Avatar
Default tcs light and throttle pedal
hello everyone iv got an issue with my trans am after h/c/i and new trans install.
I started my car to check for leaks and car was started on only with headers on to make a quick check before i finished the rest of exhuast still up on jack stand and no rear wheels on yet. I get into the car to turn it off after everything looked good and notice the (low traction light come on and go off) in the gauge cluster and then notice when it was doing that the gas pedal in the car would pull on it own like if you where stepping on it for gas and would let a off when traction light shut off. The car idles fine 900-1k rpm this is an automatic and even when the pedal moves it still idles fine, every bit of info would be helpful thanks.
car has a mail order tune also and air delete
Old 08-23-2014, 08:57 PM
ovaboost's Avatar
bump its the low traction light that pops up and the throttle pedal moves anyone know what could be the issue?
Old 08-25-2014, 11:18 AM
sicksspeed's Avatar
If wheels off ground and turning in rear then that is the issue. Place in park and that will stop.
Old 08-25-2014, 06:50 PM
ovaboost's Avatar
the car is in park and no wheels turning would breaks affect it as well if they the line had air in them may have to bleed them
Quick Reply: tcs light and throttle pedal
