PCM related? Tried to troubleshoot a sound, car won't fire off now.
Old 08-26-2014, 07:07 PM
camar0corey's Avatar
Default PCM related? Tried to troubleshoot a sound, car won't fire off now.
So I've been having this problem with what sounds like a lifter, even though I have replaced all of the lifters.
It is a 94 Z28, but I am running the 24x setup.
I started going cylinder by cylinder yesterday, unplugging a coil and listening to see if the sound changed. I did all of the the driver side no problem, same deal for cylinders 8 and 6.
Unplugged cylinder 4 and almost thought I heard a change, so I went to plug it back in. I had trouble with it a little bit, car then stalled.
Now the car will crank but not fire off? I have no trouble codes.
Could it stalling out have screwed up the crank position sensor reading or something? Should I disconnect the battery for a while and then try?
Anyone have a problem like this before? Cranks no problem, I have fuel pressure too, but seems like now I have no spark? Shouldn't it try to fire off??
Old 08-28-2014, 02:47 PM
Hmm hooked the battery up, crank crank crank. This thing just won't fire off, like there is zero spark, won't even sputter. What in the world have I done to this car? haha. Could I have damaged a relay or fuse when I tried to plug the coil for cylinder 4 back in???
Quick Reply: PCM related? Tried to troubleshoot a sound, car won't fire off now.
