PCM ground wire issue
Old 08-27-2014, 10:18 AM
Ryans99ls1's Avatar
Default PCM ground wire issue
Can anyone tell me what wires (pin #) from the PCM ground on the back of the driver's side head? I had 1 pull out of the factory crimp (which cause everything to go haywire) and i got it sorted out for now but i'd like to make it cleaner by re-grounding it closer to the pcm.
Ive read the pinouts for our pcm but i havent found the wiring diagram of where they all actually run too.
Old 08-27-2014, 11:33 PM
MontecarloDrag's Avatar
Pins 1 and 40 blue connector,
Pins 1 and 40 red connector
All of them go to a splice in the harness then to G114
Quick Reply: PCM ground wire issue
