having a issue could the tune be it?
Old 09-25-2014, 01:08 PM
cordova87's Avatar
Default having a issue could the tune be it?
Hey fellas so I completed my LS swap on my Foxbody. But i'm having some sort of issue with the car. Havent had time till now. Car starts up fine and drives but at WOT I LOOSE POWER like something is holding it back RPM's go up fine but car just wont grab or pull like it should feel's like it wants to. Any ideas what could be the issue would be helpful. I dont want assume but here's a couple thing I have in mind.
1. Not enought fuel...i still have the stock 4cyl fuel pump with a corvetter FPR
2. maybe i need a tune, PCM was flash a deleted the vats
3. Trans could have a issue, fluid looks good, but ill check it again
4. torque management
Keep in mind that cars drives fine and shift fine had a guy check it with hptuners and said gears went in all fine.
What can be the issue? __________________
Old 09-25-2014, 01:15 PM
thunderstruck507's Avatar
MAF sensor is a common place to start for poor WOT performance.
You can test it by unplugging the MAF and see if it runs any different.
Old 09-25-2014, 02:56 PM
cordova87's Avatar
thxs ill look into that but dont you think i would be getting code if it were the MAF?
Old 09-25-2014, 04:49 PM
LSX Power Tuning's Avatar
I have seen 10X more bad mafs with no codes than with codes.
Old 09-25-2014, 04:52 PM
no, the pcm will often not throw a code unless the maf is completely failed
if the maf is just dirty or reading inaccurately due to poor calibration in the tune then it probably won't throw any codes, just run poorly at WOT because the PCM is relying on if for airflow data and getting highly inaccurate results
Quick Reply: having a issue could the tune be it?
