Stand alone data logging issue with Hptuners MPVI Pro
Anyone have any tips for getting the stand alone logging feature to work on hptuners? I have the latest scanner software. Not sure if there is anything else that needs to be updated, but I tried it step by step from the help file with zero luck. Hoping to do a couple logs at the track tomorrow night with my new sloppy transbrake! I have tried loading the config multiple times both slow and normal speed. Every time when I unplug the laptop and click and hold record the err light illuminates. I tried making a new config just for stand alone, nothing. No logs are visible and I do not see a place to find any error codes.
Well messing around with it after some helpful suggestions from some guys on facebooks yielded a result. After powering down the unit, bringing it inside for a while and going back out and plugging it in the car, it started logging without issue....just weird. So I guess the tip is to power it down completely before attempting to log with it.
Thanks, I was getting frustrated with the same issue. Yes, powering everything down after loading config file to unit no worked for me as well. Looks like HP Tuners needs to add a tech note to their instructions.
