Is my MAF failing?
Is my MAF failing?
I have a stock 2002 Z28 Camaro and have search for a similar topic. I installed a WBO2 and I noticed that at WOT the engine was going lean (AFR=16.5). At 60 mph cruising, the AFR runs 14.5. I have notice that my LTFT are running high at about +20 on both banks at 60 mph. I have check the following:
1. Check the fuel pressure, which is good and increase with WOT run.
2. LTFT are essentially zero at idle and I have no evidences of vacuum leaks.
3. The LTFT banks are essentially equal and I have no evidence of exhaust leak.
4. The drive side O2 sensor was replaced.
5. I replace the fuel filter.
6. I cleaned the MAF very carefully.
I read in one of the post that you can tell if the MAF if failing by disconnecting it and resetting the trims and going for a drive. But it did not tell me how to interpret the data. I did this at 60 mph. With my MAF disconnected both banks of my LFTF read approximately +5. With my MAF connected both banks of my LFTF read approximately +15. Can I assume the MAF is failing? Is so, is there a good replacement MAF or should I just stick with the OEM?
John
John
Thanks for confirming that the MAF has failed. I had no codes and the maf hz increase with the throttle. There are a fair number of generic MAFs out there, does anyone have a recommendation.
I'm having a similar issue but my LTFT's are -10 to -14 at idle, -5 or so when driving. My short terms are 0.
I disconnected the MAF and LT and ST were all 0 +/-5. Does this indicate anything or is this how it's suppose to act?
I don't mean to highjack your thread OP. I was going to start my own thread but found this one is close to my problem.
I bought a remanufacture MAF and that fixed my problem as I am no longer going lean at WOT. There were no codes that my MAF failed, but here is a graph of my LTFT for the old and new MAF.
@LilJayV10 Like you stated, at am currently running negative trims on the remanufacture MAF and I do not know if it needs to be corrected at this time. I am going to drive it for a while. I will be interested to hear if someone know the answer to your question, but I assume the remanufacture MAF is good, but may need to be tuned.
The stock VE table wasn't even that bad too lol...it needed a little work with the wideband, but nothing major.
