44 degrees of timing at 4,000 rpm
Old 10-07-2014, 08:38 PM
draab2006's Avatar
Default 44 degrees of timing at 4,000 rpm
Hey guys, I have HP tuners and I have been trying to diagnose some minor detonation/pre-ignition my car has been experiencing when it's hot outside. I noticed however that my histogram for timing logged a lot of reads of 40 degrees of timing, with some as high as 44 degrees. Is this normal? This seems like it's a little too advanced, I would imagine somewhere in the 30's is normal. It seems to only be in the 40's when the cylinder air-mass is under .2, anything higher and it gradual dips down to as low as 20 degrees. Am I being too worried?
Old 10-08-2014, 06:29 AM
ddnspider's Avatar
Received 1,736 Likes on 1,297 Posts
Yes that is normal, most RPM in the low g/cyl region are in the upper 30's to 40 degrees.
Old 10-08-2014, 09:18 AM
MontecarloDrag's Avatar
There are some calibrations with even 50 degrees in the areas of very low load
Old 10-08-2014, 10:31 AM
draab2006's Avatar
Thanks for the reassurance guys! I am particularly weary of any readings I see because I have noticed pretty considerable detonation at around 2,000 rpm under load. It is especially noticeable when it's over 85 degrees outside. With HP tuners, is there a good way to "see" detonation via knock sensors via logging?
Old 10-08-2014, 06:05 PM
Yes, include the PID called "Knock Retard" in the main table. It will register any knock the sensor can pick.
Old 10-08-2014, 08:39 PM
draab2006's Avatar
Awesome, thank you!
Quick Reply: 44 degrees of timing at 4,000 rpm
