98 Z28 deleting codes
What do I need to delete the A.I.R pump? I have access to LS edit but no way of connecting it to my laptop, the lead connections won`t match up.
I know someone who has EFI live but his car is a 2000 model. would buying a 97 Corvette licence work as the engine was transferred to the Z28 for 1998? or am I way off?
OK thanks. never used EFI live, how do you set it up for the 98 if no licence needed? is it straight forward to use? I take it I can copy and keep the original of my PCM and then modify a version to delete the codes?
Just read out the stock calibration and save it. Make all your changes to the calibration, save it with a new name and calibration flash it into the pcm. It wont ask for a license when you flash it. On a 99+ it will ask for you to license the pcm when you try to flash it.
