Diablo Predator tune, good or no good?
Hey guys, sorry if this has been covered, and I'm sure it has, but I literally know nothing about how to or reading tuning. I recently bought a 2002 Camaro, LS1 6 speed. When I got it home I was checking it out and was pleasantly surprised to find a Diablo Predator tuner in the glove box. Along with it was a note from I assume the previous-previous owner. (The kid I got it from only had it a few months and got in trouble w/ mommy and daddy so they made him sell his car.) Here's an abbreviated version. I'm leaving out the obvious and unrelated parts.
WOT Fuel Mixture
2k-4k +8% rich
4k-7k +5% rich I know the 2-4 and 4-7 is RPM, but +8 & 5% of what?
WOT Spark Advance
2k-4k +2% Advance in winter (Use 1% in summer)
4k-7k +6% timing I've heard of x degrees of timing but not %.
Idle
Park/Neutral: w/ac +100
Park/Neutral: w/o ac +100 Pretty easy, but thought I'd double check, +100 over stock?
Fuel Injector Slope
Minus(-)7 No idea.
All Torque Management
Off I'm assuming traction control?
COT Temperature
585*C No idea.
Please let me know if any of this looks off/wrong. I do t really want to have any issues late since it's my DD.
I still need to order the cable set and program from Diablo so I can data log and upload my existing tune to my PC. If the above "tune" is even what's in the car now. Any and all help is appreciated. Thanks for looking over for me.
WOT Fuel Mixture
2k-4k +8% rich
WOT Spark Advance
Idle
Fuel Injector Slope
Minus(-)7 No idea.
COT Temperature
585*C No idea.
Here is the guide on logging and what to modify:
http://diablosport.com/forum/viewtopic.php?f=26&t=917
LS1Tech Sponsor
The fuel changes are based on % of commanded AFR, so if its commanding 12:1, and you add 10%, it will command 10.8:1
The timing is in % of total timing, if you see 20* at WOT, and pull 10*, it will pull 2*.
The COT change was to disable it, ideally it does not have cats installed, if it does, they're gonna melt
In other words, since it still has cats, I should change the tune. It they're not already melted. Clearly, some people should buy a tuner if they don't know how to use it.
Would I be better off putting a stock tune back in it till I get the cables ordered? Or can I even do that with out the usb-serial and power supply?
Thanks Mike, this is the type of info and input I was looking for.
Does any one with a predator, or that's used one, know if I can change this on the handheld? I'd rather have some insite bonfire I go plugging it in and screwing something up. This is my DD and I can't afford to have it down for any reason.
