Diable u7198 shift pressure?
Got a 02 T/A had a Diablo U7198 tune. Now i got a cam and had to get a new dyno tune. After i pulled Diablo out and started the car with new cam it had a shift flare issue 1-2, 2-3 . had the custom dyno tune and it still has shift issue.
Question is what is the line pressure on an Diablo so I can check HP tune to set presure back. I think it doesnt have enough line pressure to shift solenoid or voltage is incorrect..
Anyone had this issue after Diablo tune pulled out????
Also, It shifts fine with a very little throttle. part throttle it flares shift. I only made 2 hard redline pulls because motor is new and it shifts better but still feels delayed a WOT
LS1Tech Sponsor
you should be able to find a stock tune on the hptuners tune repository, then compare your hptuners tune to it and see what the difference is
__________________
06MonteSS / DiabLew Tune
2014 Camaro 2SS/RS - LS3, 6-speed manual, short-throw performance shifter, NPP dual-mode performance exhaust, 1LE front splitter, ZL1 rockers, Z28 Rear Spoiler, all paint-matched Red Rock Metallic, BMR strut tower brace, Cold Air Inductions cold air intake, Apex Motorsports, Inc. catch-can, Custom DiabLew Tune
www.diablewtune.com -- www.diablocustomtune.com -- www.diablocustomtunegm.com
