cruise controll problems, not working
ok i wasnt sure where to post this at but i guess this is alright seeing it has to do with the computer. my cruise control doenst work, i check the fuses, wires and linkage and dont see anything out of the normal. did my clutch and master cyl since it worked last and dont remember trying it since so i wonder if there might be something else that coudl have gotten messed up. any ideas?
There's a little push button that should be held in by the clutch pedal arm,when you push in the clutch it lets out on the push button to turn off the cruise control so the engine don't rev up. If your switch is not held in while the pedal is up it will think your clutch is pushed in all the time and CC will not engage,so all you need to do is adjust it so that it is holding the button in. (You will need to stand on your head once again) I did without my cruise for years and now that its fixed I wish I would have fixed it sooner.
