where does the purple wire go?
this is a 98 pcm and engine
I am doing a swap and need to know where the purple wire on the passenger side goes. it is in the sam sleeve as the O2 sensor wire , crankshaft position sensor and low oil sensor ( i think thats what it is) , it has a ring clamped on the end of it and kinda looks like a ground wire but its purple. does it maybe go on the starter?
Also the harness that goes from the battery to the starter and alternator- there are 2 wires around the alternator , does both go on the alternator or is one a ground?
it is a considerable bit differance it looks to be between a 8-10 guage wire. ive tracked it back but appears to go into the harness that runs behind the engine and not to the pcm
