Efi live vs hp tuners - what is the trend these days
EFI live has abandoned the 411 pcm as far as I know, whereas HP Tuners is still making updates. I've been happy with my EFI live, used it for several years, but if I was choosing now, I'd go HP.
Tire Smoking Tranny Blowing Director
I've use both and for me hptuner is nice to have a 4l80e convertor stay locked when off the gas coasting since as far as I know efi live doesn't have that. I'm use to efi live though. I have hptuner tune in there right now cause my tuner likes hptuner.
EFILive still supports the 0411 (it's not on their EOL list)... they will still fix bugs, they just won't add any missing tables.
Some of the missing tables for some of the OS's are covered by user defined calibration extensions (cax), e.g for 12212156 we have some of the missing tables via cax, such as LC, injector small pulse, dynair hysteresis, M1 2->1 shift, various dynamic fueling (port wall wetting/evaporation) tables, and others.
#34
I'm in the process of preparing to buy either Efilive or HPtuners so this thread and the price has kind of leaned me toward hpt. Except I was told EFIlive has a timing per psi setting that hpt doesn't have. Is that really a big issue to any of the hpt guys? Seems like that would be a big deal
#38
EFILive: you can flash tunes from an SD card (plugged into the handheld interface).
If you use a COS, then you only need one tune since the COS reads a switch input (via one of the pins on the PCM connector) and switches to nitrous tables (see "NO2 Monitor" in the above pic).
#39
