Are 5.3/5.7/6.0 PCM's the same?
Hey everyone
Searched but couldn't find an answer. I plan on doing an LS swap in my '73 Camaro, and mounting my Th350 to the LS until I get bored of it and save up for a T56. My thinking was, get a manual PCM so there is no electronic transmission control, then I can swap from the Th-350 to T56 without having to touch the computer.
HOWEVER, if the 5.3 PCM is different than the 5.7 PCM, then I can't do it, correct? Since all the 5.3's are electronic controlled auto tranny PCM's. Or does it not matter at all, and the auto tranny controls can just be tuned out? Regardless, a 4L60E will not be in the car.
Any help is much appreciated, thanks!
That is a very broad question. Some are, some aren't. Would help to know what year and model wiring harness you plan to use. If you use a 99-02 F-body harness then I would suggest getting a 12200411 pcm from any vehicle that used it and get it flashed with a 01 or 02 F-body M6 calibration. Any competent tuner can do it. You are going to have to get it edited anyway to get it to work in a transplant. Vats, emissions deleted etc.
So is the auto/M6 difference merely just a calibration, not an actual different computer? Would a 99-02 F-body PCM work for a 5.3?
When you said you were doing a LS swap I figured you meant LS1. 99-00 F-bodies and trucks use the same PCM and 01-02 F-bodies and trucks use the same PCM, just different calibrations inside. And you can generally mix and match any calibration with any of those 2 PCMs. 03-07 classic 5.3s can be run with older PCMs. Type of throttle body can have an effect on what PCM and calibration you need. You should decide on a year and wiring harness before you pick a PCM. Big difference between 07 classic and older 5.3s and 07 and newer 5.3s. Harnesses and PCMs.
Moderator
The key issue is whether the engine has a 24x or 58x reluctor on the crankshaft.
The suggested 411 PCM only works with 24x. Every GM PCM only works with either 24x or 58x, never both.
Correct me if I am wrong, but as far as I know:
* All LS1 are 24x
* Early LS2 are 24x
* Late LS2 are 58x
* All LS3 are 58x
* All 58x GM PCM are drive-by-wire; they don't have support for an IAC.
* Many 24x PCM support both drive-by-wire and drive-by-cable.
If you insist on drive-by-cable, you need to use a 24x PCM or an aftermarket PCM.
A 58x LS2 or LS3 can be converted to 24x but it involves a major engine disassembly to remove the crankshaft.
* All LS1 are 24x
* Early LS2 are 24x
* Late LS2 are 58x
* All LS3 are 58x
* All LS1 are 24x
* Early LS2 are 24x
* Late LS2 are 58x
* All LS3 are 58x
* All LS1 are 24x
* Early LS2 are 24x
* Late LS2 are 58x
* All LS3 are 58x
Should I just grab one from an auto car? My thinking is this.. Currently I want to retain my TH350 for now. So, tune out the automatic transmission controls when I get the PCM tuned. Then, if I want to go T56, that's already done and I can slap the T56 right in, correct? Also, if for any reason I want to go 4L60E I can just retune the PCM for the auto trans.
Is this correct?
Moderator
There were several F-body PCMs. The '98 is an odd-ball and you want to avoid that because it has a unique harness connector pinout.
You simply want the "411" which IIRC was used in '99 through '02 F-body and a bunch of other cars.
You might consider buying the 411 from ebay seller "spareecm". I just bought another one from them for a project and the price was $89 including having it "tuned" for A4 or M6, Vats on/off and any desired VIN. Yes, if you select one for M6, it should work fine from your TH350 and later for your T56. You may have to disable a few codes for the TH350; the spareecm guy might know if that is needed and do it for you.
I suspect some sponsors here can sell you a 411 for a similar price.
Thank you for that! I saw a mention of this on NastyZ28, but didn't know what they were talking about exactly. So then a regular F-Body PCM should work perfectly. Here's my remaining question:
Is this correct?
Is this correct?
Awesome! You guys rule, thank you very much!
Thanks for saying that. I knew it "can be done" but wasn't sure how that all works as far as HPT, vs EFI Live vs Tunercat. It seems like everything I need/want to do in HPT, it's 2 credits. I have the new Beta version with segment swap, but to "upgrade" the OS, I haven't seen anything on that.
