Tuners ? 58 tooth reluctor?
Old 02-28-2015, 07:00 AM
dmiz0420's Avatar
Default Tuners ? 58 tooth reluctor?
Can a 58 tooth reluctor ring be used on a 24 tooth ls1 system when you tune it?
Is there a setting in the program that allows you to switch it when you flash the PCM with efi live?
Thanks!!!
Old 02-28-2015, 11:16 AM
LSX Power Tuning's Avatar
You can not just change a table and make it work. Your only option besides changing the reluctor wheels on the crank is to run the converter box from lingenfelter.
http://www.lingenfelter.com/mm5/merc...gory_Code=C163
Old 02-28-2015, 03:21 PM
dmiz0420's Avatar
thank you, fortunately its not in the engine.
Quick Reply: Tuners ? 58 tooth reluctor?
