Idling issue after cam install and Dyno tune
Old 02-28-2015, 12:50 PM
cfer49's Avatar
Default Idling issue after cam install and Dyno tune
I believe this is a tuning issue. Car runs and idles great. But when you cut it off at a store or to get gas the problem starts. It will crank and idle fine but then when you try to pull out and have to stop it will die. It will do this every time you cut the car off for a few minutes. And you have to drive the car 5 or 10 minutes before it stops doing it.
Quick Reply: Idling issue after cam install and Dyno tune
