97 lt1 camaro tuning
First you are going to have to find someone or a shop that has Tunercat OBD2 or LT1Edit for OBD2. Not many do. Or put a 94-95 PCM in it and use an OBD1 tuner. Your data logging options are limited with both options also. I have TC OBD2 and I even turn down a lot of modded LT1 work because of the limitations that scanners like HP Tuners have when using it on them.
You will probably find more support for your vehicle on camaroz28.com
