5.3 swap with manual trans. wont rev hi code p1860
just got my bmw 5.3 with manual trans running. it has cam ls1 intake and so on. car idles great. if just tap the throttle a little it revs up a bit, but wont rev very high. if you ease into it might get 4g out of it. hooked my scanner up and got codes p0650 and p1860. seems odd since i don't have automatic trans and pcm was tuned but can it be possible they didn't set up for manual trans? or do i need to put power or a ground to another wire off the pcm to fool it? cant think of anything else.... any help would be appreciated!
jeremy
jeremy
