After Cam Install Tune
Old 03-26-2015, 01:23 PM
JonRuh's Avatar
Default After Cam Install Tune
Im going to get my car dyno tuned after the cam is installed but im curious about driving it to the dyno. I'm installing a smaller cam 222/225 @50 .561/.578 112 lsa. I've also got a set of 243 heads as well. Will the stock tune be ok for the ride to the dyno (150 miles) or should I get a mail order tune to be safe? I've currently got a tune from frost for the old mods that are in my sig, not sure if that makes a difference.
Old 03-26-2015, 01:31 PM
thunderstruck507's Avatar
As long as you didn't also change fuel injectors you should be fine, that's a pretty mild cam. Put the best premium fuel you can get locally in the car.
Just NO heavy throttle and definitely no wide open throttle. Be cautious when slowing or coming to stops in case it tries to surge and stall, don't want to get hit by someone not paying attention.
Old 03-26-2015, 01:56 PM
JonRuh's Avatar
thank you
Quick Reply: After Cam Install Tune
