P0121 and ASR help!
P0121 and ASR help!
I getting this code and my asr has been tweaking out. I've changed the map min and max values to 75/85 useing HP tuners and its still tweaking. I even got a new tps sensor and nothing. Could my ported TB have anything to do with it? I aint throwing any other codes exept P0121.
Thanks.
Thanks.
LS1TECH Sponsor
Do a search on this code.There is a lot of information. I ended up changing an AC sensor to fix the problem you are having. There is a lot of info on why this happens if you search on p0121.
Does this code tweak out the asr?
Originally Posted by SAINT WS6
I got the exact thing problem myself! Driving me nuts cuz the car starts shifting funny as well and goes into limp mode...
It's actually being fixed right now, but from what I've heard, you just have to change the MAP min/max test parameters to like 65/85, or higher than stock, using LS1Edit. That should cure it.
