Tuning 101
Old 04-19-2015, 09:07 AM
1Hotbird's Avatar
Question Tuning 101
I have EFI live and need a little direction please!
We took a 99TA LS1 auto and shoved it into a 87 formula, later we pulled the auto trans and installed a 6 speed.
I got into the tune and did what needed to be done to delete the auto trans, EGR, Air, ect.
The engine is stock at the moment except full headers, no cats, slightly different air intake tubing, EGR deleted, Air injection gone, ect...
The car idles fine runs ok but bucks and surges occasionally.
So last night I pulled out the EFI live cable (older style) started trying to pull logs ect... I am able to log now and figured out how to export the data to Megalog viewer (I'm used to looking at data logs this way)
So I need to order a Wideband and get it hooked to the logger, then I think I need to unplug the MAF sensor and dial in the VE table, reconnect the Maf and possibly tweek the Maf curve???
This should be fairly easy as its stock now but once I'm comfortable with it we want to install heads/cam ect....
Any help you can give me or point me to threads to read would be greatly appreciated!!
Also I can only log with the laptop in the car, anyone know how to get the interface cable to log then load to pc later? Cable says; Flashscan FSP V1.2
Thanks
Old 04-19-2015, 10:44 AM
1Hotbird's Avatar
Old 04-20-2015, 08:50 PM
1Hotbird's Avatar
Ok then. Is there a video tutorial I can buy or a class I can take?
Old 04-20-2015, 10:07 PM
eaglegoat's Avatar
https://www.google.com/search?q=greg...pvd=1&ie=UTF-8
Start there
Old 04-24-2015, 10:05 AM
1Hotbird's Avatar
Originally Posted by eaglegoat
Thanks.
I have some tuning exeriance but only open loop and no mass air. No narrow band o2. Only used wide and to dial in a very table.
Also have Motec experience, but also open loop, no maf.
I'll just jump in with a wideband and see what happens.
Old 05-05-2015, 01:41 PM
JetMech442's Avatar
EFIlives forums have a sticky for CALC.VET tutorial. It corrects the maf AND the VE table in the same logs. Weatherman Shawn and JoeCar have an awesome setup which includes all the PIDS in a txt file and the procedure mapped out. With your experience, this should be right down your alley.
Using this procedure you leave the MAF and NB02's hooked up. Just plug in your WB(Serial connection is best), create the maps for VE and MAf BEN's, and go grab data. I'm in the middle of doing it myself and it works great.
Good luck, hope this helps.
Old 05-05-2015, 08:18 PM
1Hotbird's Avatar
Thank you! Working on a few other projects on the car first. Will be tuning soon.
Old 05-07-2015, 08:25 PM
joecar's Avatar
I can show you how to do BBL with your FlashScan V1 (i.e. no need to bring laptop on street logging sessions)...
Old 05-08-2015, 06:14 AM
1Hotbird's Avatar
That would be great!
Old 05-10-2015, 05:38 AM
joecar's Avatar
In the scantool user manual pdf, goto page 109 (pdf page 111/195), see page tit;e "Black Box Logging", start at "1. Validate Pids"...
have a read thru this section, and I'll get back to you.
Old 05-10-2015, 09:27 PM
1Hotbird's Avatar
Thanks Joe I read the section and think I have the cable setup for logging. I will give it a try soon.
Thanks again.
Quick Reply: Tuning 101
