Power Steering - Affect on Idle
So I did a head n cam swap a while back and it has had an intermittent problem where the idle would drop really low especially when turning (like in a parking lot). It also seemed to be difficult to turn sometimes. Anyway I replaced the fluid and it seems to turn a lot better.
Strange thing is it seems like the problem with the idle dropping seems to a decreased as well...
Is it possible my power steering pump was affecting my idle?
So I did a head n cam swap a while back and it has had an intermittent problem where the idle would drop really low especially when turning (like in a parking lot). It also seemed to be difficult to turn sometimes. Anyway I replaced the fluid and it seems to turn a lot better. Strange thing is it seems like the problem with the idle dropping seems to a decreased as well... Is it possible my power steering pump was affecting my idle?
You should find someone with hptuners and run a scan with the car running..
You might have codes popping up that won't show a SES light..
