Emissions - DTC
Emissions - DTC
I have a standalone swap where the wires for the emissions components are removed from the harness.
The PCM now throws codes for:
Rear o2-sensors
AIR
EVAP
Will these DTC's affect how the engine runs (limp mode etc.) or are they just for informative purposes?
Rear o2-sensors
AIR
EVAP
Those codes will not cause any issues. It would be better ( more convenient ) to have those items tuned out so those DTC's don't clutter things up. If the codes constantly set, you may not be able to get any Freeze Frame data ( depending on your scanner ) for a DTC that really is a problem. Just food for thought..
