Yet another LC1 Wideband thread
Old 05-12-2015, 06:39 AM
Tuckin15s's Avatar
Default Yet another LC1 Wideband thread
Ok so I have searched the **** out of this subject and can't really get a good answer so I figured I would post my problem here and see if I can't get it solved. I have a LC1 with the blue digital gauge, I am having issues wiring it up and having it work correctly. I wired it to another thread here on tech and it flashes 7.4 really dim and doesn't work at all. So I guess what is the correct way to wiring this thing? What colors on the gauge go to what and what doesn't get used? The lc1 it's self what colors get combined and and what gets used. I'm not data logging or anything fancy with it, the gauge is just there for me to monitor my AFR. I know you guys are prob sick of these thread and I'm sorry but for some reason this thing is making since to me. I'm doing a whole lot of this
Thanks,
Ross
Old 05-12-2015, 09:23 AM
Tuckin15s's Avatar
Is this correct?
Old 05-12-2015, 12:25 PM
87lsttop's Avatar
Change the white wire from the gauge and connect it to the yellow wire on the controller.
Old 05-13-2015, 06:52 AM
Tuckin15s's Avatar
Ok, cool thanks I will try that out thanks man!
Old 05-14-2015, 10:26 AM
SoonerBrad88's Avatar
If you go to Innovates website I think they have instructions you can download.
Old 05-14-2015, 12:45 PM
Tuckin15s's Avatar
O really I'll have to check it out. There is something up with it, it is just reading 10.6 all the time.
Old 05-14-2015, 12:53 PM
Tuckin15s's Avatar
Never mind I figured out my problem I have to connect the DB gauge’s WHITE wire to the
LC-1’s BROWN wire. The way it is in the pictures the way it I have the white to the yellow hooked up which is for the lc-2 only.
Old 05-14-2015, 02:40 PM
Yeah the yellow and brown wire put out a different voltage. Brown is up to 5v and I think the yellow is milli volts
Old 05-19-2015, 10:00 PM
2002_Z28_Six_Speed's Avatar
I really feel it is worth the extra cash to get a LM1 even if you end up stuffing it under the seat and feeding a gauge. I've owned both and the LC1 was nothing but trouble and a waste of my time.
Old 05-20-2015, 11:50 AM
Tuckin15s's Avatar
Yea this is my second lc1 and I can tell you I will not be buying another after this.
Quick Reply: Yet another LC1 Wideband thread
