hp tuners maf turbo tuning have a few questions
I am running low boost 5lbs water/meth kit 80lb injectors
I was told that all I need to do for the tune on this because of the low boost is to input my new injector data and leave everything alone even the timing tables because it is such low boost. And data log rpm vs afr and see if it lands where I want it.
I am new to hp tuners and maf turbo tune as well.
Does this seam correct to you guys? Almost sounds to easy. Was told the VE tables should be really close after the injector in data was put in and that the timing from the factory was already not aggressive enough on a stock ls1. Any help would be great.
I purchased the 80lbs with bigger plans in the future want to run the 5lbs until I can get more supporting mods trans etc.
