98 camaro traction control not working after 99 wiring swap.
has anyone with a 98 f-body had a problem with the traction control not working after doing a 99 wiring and pcm swap and what was the fix if any?
I'm using the same BCM that was in the car. I'm going to take it to the dealership and have them flash the BCM. I read last night that the VIN has to match in the BCM and the PCM. It worth a shot anyway. Hope you guys have luck with your issues and i will post up the result after the visit to the dealership.
red ooz28, i read your post and we went about the swap a little differently. i seen where you went with the engine harness and dash harness. i used the engine and added the c210 plug along with the wires for the water temp, oil pressure and alternator. that maybe why we have the same problem but different readings
Originally Posted by maroonls1z
You guys need to go into the fuel section with hp and have to do some trial and error to figure out what you need
So I figured out my fuel level gauge. Turns out it is reading right. This morning I went to start it to go to work and I noticed the fuel pump sounded different when I turned the key. Hit the key and it was stumbled then died. Out of gas... put 5 gallons of 91 in it and it's between 1/4 and 1/2.
lol well that's good. embarrassing but good
Now onto the service vehicle light and the ASR not working. I pretty sure the service vehicle light means a bcm code probably due to the asr
