No intake air temp reading
I just changed over to a 2 bar map and eliminated the maf. How ever when I read my scan it's telling me my intake air Temps are -31c. What sensor tells the computer this so I can try to figure out how to fix.
01 LQ4 lower end, with LS3 heads and L92 intake.
It was a 5 wire MAF.
So My guess is I have to Wire in a IAT sensor but would want that after the IC right?
Any suggestions on where to put it or what one to get?
Will this work? http://www.ebay.com/itm/GM-Delphi-Pa...-/331515217715
You dont have a part number do you? Or even better a sponsor on the site I could call to get sensor and pig tail?
Moderator
I've always wondered just which air position was proper
for a boosted vehicle. All along the tract you are trading
pressure, volume, temp yet the SD air mass calculation
would need manifold pressure and manifold temp to be
proper. I'm guessing that the PCM has a scheme to figure
manifold temp from IAT temp by BARO-MAP pressure drop,
in the NA stock form. But what this -should- be, for a
setup far from stock, I have no good idea and so far have
found noone who convinces me they know.
And when you have boost, and air temps, swinging wide
and fairly fast, the IAT's slowness could make for some
interesting transitional fueling issues I expect, if you are
looking for it to follow reality and quick in some after-
impeller position.
impeller position.
