Question tuning by lambda error
I know when tuning using fuel trims you want to disable things like MAF if tuning VE or DFCO, PE, etc. etc. based on your set up.
But when tuning using lambda error can't you just leave everything as is and tune the error from what you are commanding? I always disable fuel trims from the scanner so I'm in open loop.
I'm going to give my first shot at tuning a VVE tomorrow using Bluecat tool. Looks like I have a good starting point due to other peoples hard work and file.
I tune them both at the same time. Set open loop and go. I've never had a problem with running open loop fueling. To answer your question directly, no. I've only ever had a problem with closed loop fueling. That can be fixed as well ;-) .
ah so you were saying that I should tune them separately however others can tune them together..now I get you "not being a jerk" comment lol.
I'm realizing tuning using LTFT if I do them separately I can get them good but then mixing them they go off again. I do wait for them to relearn after a reflash and log then.
So was thinking about just doing as you suggest, open loop and go. Can tune MAF, VE and WOT together.
So how do you fix the other?
What you'll want to do is:
1. Set open loop
2. Set MAF only/Set SD.
3. Tune corresponding table.
4. Switch airflow mode.
5. Tune corresponding table.
6. Set hybrid mode, check logs.
7. Set closed loop, check logs.
Your pid for lambda error is correct. Your pid for commanded lambda will work, but I wouldn't use it. Move away from afr, think in lambda and in terms of lambda. EQ ratio maybe...
well that gave a weird reading lol. guess I need to mess with that. my old PID gives me a commanded lambda of 1 in my scanner.
I did log and happy with my fuel trims both in MAF and VE running them together. Made a WOT pull and a little rich so adjusting that.
Next I have a cold start issue I'm messing with. Warm/hot starts are fine, but overnight cold starts cranking are rough. I loaded the stock Idle startup airflow vs ERT vs ECT and will see if that helps. Only had slight differences from it. thanks
Bonus tip: I use 14.12 for e10 stoich
Edit: I just saw your other thread and that you're running an e38 controller. For the E38 and newer controllers commanded EQ is the same as commanded lambda. In that case you want to use
100*([AUX.20121]-[pid.68])/[pid.68]
I hate the "may contain up to 10%"
Our gas around here is so inconsistent. You can get pure gas but its only 91 octane. All 93 is the "may contain" so I split it
Winner, winner, chicken dinner!
Make sure you verify your wideband ground and offset every time you tune with lambda. Turn the key on, start the hpt log and put power to the wideband. The afx outputs the lambda voltage for like 10 seconds during the 20 second power up sequence.
