Removed EGR. Experiencing some KR at part throttle
Is it possible that removing EGR is causing some KR? I see from 0.1 to 4.4.
I did not have a scanner when I removed the EGR.
I can't really think of anything else I am doing that would cause it.
I run TR6 plugs
I have a 160* thermostat and appropriate fan settings
I run 93 ocatne only
I have used top end cleaner recently
I am using no oil to the best of my knowledge.
I have an A4 w/TCI SSF3500
I get very little to no KR @ WOT when on a 75shot.I sometimes see around 0.1
Usually when I see the KR my LTRIMS are positive.
What would be the best way to counteract this?
I run TR6 plugs
a) get a MAFT (MAF Traslator) and bump up the "Base" fuel level and cut the "WOT" to even everything out.
b) get LS1Edit and retune that way
I vote LS1Edit just because it is better in the long run (heads/cam/headers/etc. all need more tuning ability that a MAF can do).
I understand how the EGR system works. I didn't know if the PCM would account for the fact that EGR is no longer working or not. From what you say it is not going to.
I have HPtuners.I am wanting to add fuel at WOT but am not sure of the best way to do this.As far as the part throttle KR. You think I need to add fuel? Where?Again,how? IS there timing that should be pulled due to the EGR being removed?
I tried making some changes in the PE vs.RPM field but the help file states this is for 99+ cars. I have a '98. I also changed the PE MAP value from 15 to 13 because I did not see MAP values of 15+ during any of my wide open runs.
I am fairly clueless to tuning via HPtuners or any tuning program for that matter. I have been a carb guy my entire life.
I am not afraid to get in and work with a program nor am I computer illiterate.
I do lack some basic information concerning the tuning of this vehicle. I need a FAQ or something.
