Holley HP efi tuning help
Hey guys so I finally am getting around to fine tune my holley system, I got the idle almost perfect. Starts right up, idled it the other day for a good 10 minutes and everything was rock steady. BUT there is something very odd to me. It idles at around 750-850rpm but there is almost ZERO cam lope. I am running a somewhat aggressive cam so I thought that was very odd.
HERE IS THE MAIN ISSUE THOUGH:
When I tip into throttle slowly the car wants to kinda bog down then it will kickback up. Now the thing I find odd is, with learn ACTIVE and me holding the rpm at any point above idle the afr will start jumping around. From 11 to 14.7 then up to like 18 then back down to 14.7 and the learn table keeps changing over and over. I tried transferring and it doesnt help. Car is at a constant 13.4-13.5 volts. Also it seems like if you hit the throttle hard to blip it, it wants to die but if you slowly raise the throttle up it will go up no problem
SETUP:
lq9 bottom end
ls3 top end
BTR stage 4 cam kit
ls3 intake
br7ef plugs
th400
ALSO!! I remember there was a guy on here that does a lot of holley tuning and can remote tune the systems. I just cant remember his name on here. I think it was like losls2?
SETUP:
lq9 bottom end
ls3 top end
BTR stage 4 cam kit
ls3 intake
br7ef plugs
th400
what base tune did you start with?
SETUP:
lq9 bottom end
ls3 top end
BTR stage 4 cam kit
ls3 intake
br7ef plugs
th400
SETUP:
lq9 bottom end
ls3 top end
BTR stage 4 cam kit
ls3 intake
br7ef plugs
th400
Because Iam still not using a 1 bar sensor. I am using the 3 bar sensor with 1 bar sensor scaling. I figure it should be fine since its not boosted and I dont need it to read more then 1 bar anyway.
I am using the 3 bar map sensor with the Y axis numbers from a 1 bar sensor. But it idles perfect, goes in and out of gear fine, revs like a raped ape, AFR is spot on it seems. Only thing left to do is take it for a drive. Just don't want to risk anything.
So pretty much I did as follows:
Loaded the 480hp ls2 map, selected gm 3 bar sensor, went into the base fuel map and timing map and made the Y axis range from 0-105kpa
Why not use the setting for the 3 bar map sensor under the senors tab? I'm not looking at my software now, but there is a drop down for the LS3 3-bar MAP with the part number listed next to it. Are you running V2 or V3 software?
As for your AFR hunting at idle, there is a delay between the O2 sensor and the actual reading. The system will end up "chasing its tail" if the Close Loop/Learn Advance control isn't right for the application. I was never satisfied using the learn below 1500rpm with my LS6 cammed 5.3 so I manually tuned those areas.
Your off idle hesitation should be cleared up in the acceleration enrichment tables. Highlight the AE vs TPS Rate of Change values, right click, Offset selected, then *1.02. Repeat until the lean condition and stumble are eliminated. If you have an excessively rich problem, multiply by .98 and work that direction. Good luck and have fun.
I did chose the ls3 3 bar but that only changes the Y axis and the base fuel stays the same. So what I did was select the 3 bar sensor, then changed the Y axis to read from 1 at the bottom and 105 at the top. Working GREAT! Fixed 99% of the issues. Still have one very minor issue and that is starting when Hot. I have to give it a slight tap on the accelerator to keep it on when first cranked on.
Andrew
