2002 Trans Am idling strange when cold! help please
I noticed the following in my 2002 Trans am idling, and i will need your help guys:
The car is cold, I run it … wait until it gets up to the operating temp (180-185), then i see at idle my rpm is 980-1050 …. never goes below..until I do the followings:
1- if I turn it off and on again , the rpm goes to normal range immediately (850) .. check the first video.
2- if I put the shifter in R , the rpm also goes to normal range immediately (850) … check the second video, right after i push the acc and then put it on reverse , the rpm will fall to normal.
--- both videos are on different days at cold starts
Having said that, if the car is warm enough and I come back to run it, the rpm starts very normal and goes to 850. however, in this start, it struggles to start normally , something sounds like battery is low (which is not low, i checked it) , or something sounds like the fuel pump is not functioning properly!
if the car is cold this hesitation at the start doesn't appear and only there is this high idling issue.
I have never had this issue before and my car is standard.
Any ideas guys will be much appreciated!
Thanks
Thanks
1. Clean your Throttle body
2. Check for a Vac leak.
3. What is the outside temp where you are located? or do you keep it in a cool garage?
When its cold out, cars idle high to warm the engine up, to operating temps faster, and warm up the cats.
It's right around 1,000 rpms until its warmed up. Could be normal - and most likely is.
Moderator
Received 1,835 Likes
Is that noise that sounds like a bird chirping 5-7 times near the end of the second video a car noise, or is it in fact a bird?
If that's a car noise, that's weird.
Is your transmission manual or auto? The reverse thing might indicate something transmission related if it's an auto. If it's a stick, might indicate a loose ground in the console.
Try this - Remove the connector for the TPS and the IAC. key on, engine off (ON, not accessory power) for a few minutes. Key off, plug back in the sensors and start the car. That's the idle relearn procedure. Might be all it needs...
This is a manual trans .. if it is really a console grounding issue, would it be such a problem to trace the source and fix?? or just leave it as it is
I will try the idle relearn procedure , and check if that helps! thank you so much.
Moderator
As to the bird, I can't hear sounds like that with the car running. Something about long tubes and lifters. So I wanted to make sure.
Hope the idle learn helps
