Upgrade from 2bar to 3bar
I'm looking to go to a 3bar OS to run a 2.5 bar Map sensor. I currently have a 2bar OS from a 2002 Camero with a 4l80e segment swap. Can I use my current tune or do I have to start from scratch? If I have to start over, does anyone have a base 2002 Camaro tune (156) with the 4l80e segment swap already done? I would gladly pay if that's what I have to do to get this done.
Should just license it like normal, its just a stock tune with segment swap done. A segment swap doesnt affect licensing.
Do you have your stock file that you licensed? Do the segment swap on that file you will not need to re-license it. If you never licensed your stock file and only licensed the 2 bar file you will have to license a stock file in order to start over.
