Using HPTuners Repository Tune
I added a few upgrades to the LQ4 in my Chevelle and I'm wondering if I can use a repository tune to roughly dial in my engine. I've already changed the tune for the manual transmission, removed the rear O2 sensors, and updated the injector data. I found a file on the repository from an LS1 with similar parts and I'm wondering if other data can be safely copied from the file.
Here are the details of my LQ4:
799 heads
EPS cam 230/234 .629/.629 112+2
LS6 intake and injectors
Long tube headers
LS7 clutch
I have a couple logs of the engine idling but I think the pump was picking up old gas so I don't know how helpful it would be. I can upload them if they would help. Thanks!
799 heads
Long tube headers
LS7 clutch
You could try it. Cover the basics for your car on your own then copy the VE from theirs and see how it goes. If you have mechanical issues like bad gas you need to address that first.
So the VE should be close even with the different displacements? It's picking up fresh gas now so that shouldn't be an issue.
I attached one of the short idle logs. I'm not exactly sure what I'm looking for but it seems like there's a lot of ignition advance when the engine speed increases.
It should get you close but you will still have to tweak VE. Look for the Russ K idle config and get your base running airflow dialed in. You also need to get your iac counts dialed in at hot idle.
I took the Chevelle for a real quick test drive and the engine did not want to rev past 2200 rpm or so while driving. What would be the cause for this?
The log from the drive is attached if that will help. The thing that jumps out to me is the timing advance. It seems to jump between 0 and 30 degrees without reason.
two things that stand out to me on your test drive is your tps is at 18% is that with you on the pedal or not. Your tps should be no higher than 3% at idle in park. second you need to add your iac counts so we can see if your in the right range. That has alot to do with why your tps is off.
