6 Speed flash for TH-400 car
Years ago I used to just delete all the codes for the auto transmission and not flash them over to a manual and had several vehicle start doing really weird things with timing. As soon as I flashed them over to a manual they went back to normal and have never done it again. Will it work deleting codes, probably but its easier just to do it right and make it a manual and not potentially cause any issues later IMO.
You are correct. It is definitely best to flash it over to a manual so the computer is not looking for anything transmission related.
Ive used manuals, and autos on 60 and 80e OS's, never have had an issue.
if you are using an e38 or anything with a separate T42, you'll need to flash a manual OS.
cheers
Not this ^
This ^
I have done both ways and got good results, never had weird behavior with timing or anything.
It's not always possible/practical to change to a manual OS so you have to learn to think outside the box and work with what you have.
I am aware of that. Based on that, even GM has automatic OS's running manual fbodies, hence why you don't need a manual transmission operating system or 'segment swap' to run a manual or a th400. There's no need to switch to a manual OS since even from GM they come with an automatic segment on the calibration yet with a t56.
When I said he needs a new OS is the fact that he is "searching" for some magic option on his current file to convert it to manual, in which there is a drop down menu on the transmission portion that allows you to select "manual" but doesn't do anything. In order for him to not get any MIL without doing no error reported on em, he needs an OS from a manual. I'm sure you know this, but he doesn't, and may need to pay an extra 100$ just to do that which for what I said, you don't need to change anything if you go from an auto OS then slap in a th400 or m6.
You get a calibration from the same type of vehicle with a manual transmission and do a Write Entire of that file to your PCM. Model year of the file must be compatible with the PCM you are writing it to. And the rule with HP Tuners is you have to have a license for the file you are writing and the file that is currently in the PCM. So converting it to a manual could cost you some credits. You will then need to copy the tune over to the new calibration. And there will be some tables shouldn't be copied exactly because of the difference between auto and manual calibrations. Don't take offense, but i've been seeing your posts here for a while and I would guess you are still going to be lost.
LOL! Yeah, can't seem to get a grasp on this tuning but still trying to learn. I'm making little steps though.
I'll get my tuner to flash the manual file. I really need to sit down with him and learn this stuff. Never seem to have time, so I'm trying to learn this on my own with the help of this site.
