Idle surge (mostly in Park/Neutral)
#121
I did a full write to ditch the trucks tune and I used my LS2 base tune. And the car runs and idles perfect minus the original park neutral surge which is barely noticeable compared to what I've been dealing with.
Note: this tune is based off my ls1 tune for the ported heads and 230/238 Cam Motion cam. I think the only real changes were to the displacement.
I guess something has been corrupted along the way. I will use the compare function and look at every difference between this tune and the newest revision and see if I can nail down the problem. I might just run a new CALC.VET on this one and go from there....the IFR table might not be "correct" but at least the tune works.
Here are the tune and the log:
#126
Doing a CALC.VET on that tune file will make your tune worse... it still has the minimum pulse set too high. I should have looked at your tune file before saying anything... my fault.
Here's a tune file with all the fixes applied.
#127
also, are you running non resister plugs ? some cars that will screw up the computer(mine) also how about the metal covers/springs on the boot ends ? the 24T engines are far more prone to RF interfearence...found this out the hard way, and with swap sometimes grounds, RFI can drive you crazy
#129
Just went for a tuning run and I can't even tell you how much better this is everywhere. The absolute only thing is coming to a stop with real quick off throttle is it dips down a little low but it just comes right back up and idles rock solid so that should be an easy fix.
It was running so good I didn't want to park it. Throttle response is already worlds better, really lets the solid roller shine. Little more touch up and if all goes well I can hit the dragstrip Sunday for opening day of the season.
*cheers* to everyone in this thread who has offered up opinions, tips, and was patient with my ignorant ***
