1997 S-10 stock tach ppr?
Old 02-11-2016, 01:03 PM
Trentec's Avatar
Default 1997 S-10 stock tach ppr?
Setting up a 4.8 for swap and having trouble finding the ppr for the factory tach. The truck had a 4.3 5 speed.
Thanx in advance for any help
Old 02-14-2016, 12:04 PM
Trentec's Avatar
Ok then does anyone know if it's a four cylinder tach or six?
Old 02-15-2016, 10:50 AM
TrendSetter's Avatar
http://www.currentperformance.com/s1...custom-wiring/
Old 02-15-2016, 12:39 PM
Trentec's Avatar
Trying to calculate the setting for the 0411 6 or 4 I know it's possible just wanted to get it right the first time. 6 and 4 are the tach settings in the software 6 is a four cylinder output and 4 a six. Go figure.
Old 02-16-2016, 03:06 AM
Pacer Racer's Avatar
That's because it's the number it divides 24 pulses by, if you divide 6 into 24 you get 4, if you divide 4 in to it you get 6 if you divide 3 into it you get 8
Old 02-18-2016, 02:28 AM
Trentec's Avatar
I'll post the answer when I get the engine running.
Old 02-18-2016, 07:53 PM
rpturbo's Avatar
Mine is a 94 that came with a 4.3, and mine is set to 4. It is very, very close, maybe 100-150rpms off.
Old 02-19-2016, 04:32 AM
Trentec's Avatar
Thanks for the info. I will start there.
Old 04-05-2016, 10:39 AM
Trentec's Avatar
The tach if I had slowed down and thought about it...😁 was connected to the coil of the 4.3 so it is a six cylinder tach. So the setting was four. Thanks for the input! Truck runs great and makes an excellent every day driver.
Old 04-05-2016, 11:28 AM
rpturbo's Avatar
Yeah I really really like mine as a daily, and it surprises LOTS of people. I love smaking it to a newer 5.0. LOL
Old 04-05-2016, 03:14 PM
Trentec's Avatar
Not sure about taking on any mustangs but the roughly 300 horse with the 5 speed is loads of fun to drive and everything works just like before including abs etc... The 97 is an odd ball so I was really happy to see it all work right the first time.
Old 04-12-2016, 08:58 AM
Trentec's Avatar
Just in case anyone has the same problem. We switched to an after market fuel gauge and needed a 0-90 ohm sender (stock for 97 s10 is 40-250) after reading a bunch of articles and how to's some good some silly. We found out the 1996 s10 / Sonoma has a 0-90 sender that clips right in problem solved. Just need to re-pin the connecter plug no big deal. This sender will probably fit most late model pump buckets as well.
Best regards
Old 04-14-2016, 10:59 AM
gagliano7's Avatar
In hptuners my tach outputs high and low res are set to 3 for my 1992 chevy c1500 pickup tach. That is from a 1999 pcm 5.3 truck.
Quick Reply: 1997 S-10 stock tach ppr?
