Running rough under load/ spark plug darkened
Old 05-05-2016, 05:59 PM
ul-ss's Avatar
Default Running rough under load/ spark plug darkened
I have a 01 camaro with an lm7 engine, Texas speed heads, ljms cam, 80lb injectors Lonnies double pump kit, tr7ix plugs, msd wires, and a Huron speed turbo kit. I took the car to get tuned after I installed the turbo kit, new cam and injectors and it was having issues he said to check compression. So I did a compression check and everything is within a good % of one another, fuel pressure reads fine. I pulled the valve covers and everything looked fine under their. When I pulled the plugs #7 was much darker than the the rest of the plugs and the car only really runs rough at about 1800-3000 rpm. Are there any other tests or anything else I should check for? Maybe should I have another tuner check it out?
Thanks for any help!
Old 05-05-2016, 09:51 PM
Moderator
Darth_V8r's Avatar
Received 1,835 Likes on 1,145 Posts
Sounds like number seven injector is leaking
Old 05-05-2016, 11:24 PM
ul-ss's Avatar
Should I try to swap the injectors around? or maybe just see if it is seated all the way
Old 05-05-2016, 11:34 PM
2xLS1's Avatar
Time to stick a borescope in cyl 7. You can get a USB borescope for under $20.
Old 05-06-2016, 03:59 PM
ul-ss's Avatar
What should I look for with the boroscope, See if the top of the Piston or wall is marred up?
Old 05-06-2016, 04:00 PM
ul-ss's Avatar
Also did a buzz test on all the injectors and they read fine and the fuel pressure did as well
Old 05-06-2016, 04:11 PM
2xLS1's Avatar
Attached Thumbnails Running rough under load/ spark plug darkened-piston.jpg
Old 05-07-2016, 11:22 PM
ul-ss's Avatar
Gotcha lol, ordered a borescope off of amazon should be here by monday or tuesday
Old 05-07-2016, 11:37 PM
ul-ss's Avatar
I swapped the #7 injector with #2 ran it and checked the plugs the #2 plug never got any darker than it was. Also swapped around plug #7 and #3, the plug cleaned up immediately in #3. Cylinder 7 plug didn't get much darker than it already was either, I might need to run it longer though.
Old 05-10-2016, 02:19 PM
ul-ss's Avatar
checked it out with the borescope didn't see anything out of the ordinary, Anything else I could check or do a test on?
Old 05-12-2016, 05:39 AM
gagliano7's Avatar
Could also be a bad coil for cylinder 7.
Old 05-12-2016, 06:18 AM
Old Geezer's Avatar
Misfires on a scan?
Old 05-12-2016, 01:17 PM
ul-ss's Avatar
I haven't tried swapping coils yet, should I try just buying 1 coil or maybe swap them around? No misfires on the scanner or any history of misfires. I had one code when i got it back from the tuner it was the p0200 code (injector circuit malfunction) after I swapped the injector #7 with #2 and cleared it I haven't gotten the code since. My buddy has some truck coils that I can try and hook up too
Old 05-12-2016, 03:30 PM
ul-ss's Avatar
Swapped the coils with the truck coils and same results still stutters under acceleration
Old 05-12-2016, 04:30 PM
jaydubb's Avatar
Wheres your plug gap set to? Does it only stutter under boost?
Old 05-12-2016, 04:32 PM
jaydubb's Avatar
Oh yeah... I wouldnt use anti-seize on the plugs...
Old 05-12-2016, 05:30 PM
ul-ss's Avatar
It seems to stutter more under vacuum, i haven't gotten into boost too much since the car isn't really tuned all the way yet. Stock gap out of the box, the tuner I went to recommended the plugs. Could the anti seize of messed up the plugs at all?
Old 05-13-2016, 01:07 PM
gagliano7's Avatar
I had a friend once who put way to much antiseize on his plugs and it ran terrible. Cleaned them off and it was good. To much on the threads and you lose the ground for the plug.
Old 05-13-2016, 01:20 PM
Old Geezer's Avatar
Default ???
Huh??
Old 05-13-2016, 01:26 PM
ul-ss's Avatar
I got some tr6's and threw them in and it seems to be running a lot better it's still a little choppy under acceleration, but it is noticeably better. The car isn't completely tuned though, so now I'm not sure if it's tune or the car. I didn't put any anti seize on the plugs should I pull them back out and give them a small amount?
Quick Reply: Running rough under load/ spark plug darkened
