98 LS1 Alternator exciter wire
Old 05-16-2016, 01:14 PM
Kelly Bowers's Avatar
Default 98 LS1 Alternator exciter wire
Yes, I know. Its been asked a million effin times. My problem here is with that exactly. Its been answered 999,000 times wrong (With someone rambling about how their 99 is wired up) and I just want to get this straight.
Have an ls1 out of a 98 trans am. Engine, trans, pcm, harness all out of the donor car in a 1972 GMC truck. I need to know where the exciter wire goes on the 1998 ls1 (not a 99+).
Old 05-16-2016, 02:11 PM
2xLS1's Avatar
Old 05-17-2016, 08:17 AM
Originally Posted by 2xLS1
If that is for a 98, thank you.
If not, I'm sure i'll find out soon when I'm stranded lol.
Old 05-17-2016, 11:08 AM
2xLS1's Avatar
What I posted is all I can find for a 98. I don't know what the broken connection means on the SD between the alternator and PCM block. If you look at the 98 PCM pinout, it shows C2-61 to be PCM Battery Feed. Here is the diagram for a 99-02. You can see it is a direct connection between the L-Term and C2=15. And The C2-15 is labeled Generator Turn On Signal on 99-02 PCM pin out lists. Looking at the 98 PCM pin out list there is nothing labeled Generator Turn On or L-Term.
Attached Thumbnails 98 LS1 Alternator exciter wire-99-02-charging-system.jpg
Old 05-17-2016, 11:24 AM
2xLS1's Avatar
Maybe this will help.
Quick Reply: 98 LS1 Alternator exciter wire
