My review of my TERRIBLE experience with Livernois Motorsports
#41
The sewing machine noise is a given. Mine was doing this wild 1500-2000 loud "clack-clack" crap. Only when you hold the RPM there for an extended amout of time. Come to a stop, CLACK CLACK CLACK. Oh... during this CLACK CLACK crap, I could hear an audible miss. And feel it. The CLACK CLACK would stop after idling about a minute. Or if you hold the RPM above 2000 RPM. I could drive at 75 mph in 5th gear (2500 RPM) and I wouldnt hear ANY CLACK CLACK at all!
Installed the 7.425 pushrods and viola! No more 1500-2000 RPM CLACK CLACK CLACK.
Still sounds like Grandma's old Singer sewing machine... LOL!
#42
In my state (CA), the BBB inclues the BAR which handles complaint regarding automotive repair...
but be careful, in CA the BAR also administers smog testing, and the BAR also enforces smog compliance... if they suspect your car is cheating smog (engine mods, tuning, non-CARB EO bolt ons), they will make your life miserable...
so I don't know how it works in your state, but do be careful.
#43
#44
Update: Livernois Motorsports is refusing to remove torque management from my tune. I'm sure we all know how simple that is to do. Instead they want me to travel to Michigan and pay to put it on the dyno to have it removed. Check out the emails. I called and spoke to Anthony Mahaney (the one responsible for dealing with the remote tuning) and he told me "it's turned down as much as we normally turn it down for drag racing and any further would require dyno time". Dyno time to remove torque management???
BTW just a reminder of what they claim on their website for remote tunes. "we include free tune updates for all supported performance upgrades along with true customization of your tune allowing us to make the vehicle exactly what you want it to be".
Anyway enough beating a dead horse. I'm doing what I should've done a long time ago and going to SpeedInc in Chicago.
#46
There is but at least on the 5th gens (not sure about the 4th gens) there's torque management that is completely separate from the traction control. it can only be adjusted by a tuner. It basically governs the motor. When you floor the gas pedal, the TM is turning your throttle plate back to limit and control engine power Which is supposed to be safer for the car, driveline and the driver so the car is less likely to get away from you or cause damage to the driveline. In drag racing this can really hurt your 60ft times because it causes you to bog off the line if you launch hard.
I posted an HPtuners snapshot of it someone posted on the Camaro5 forum
#48
#49
Sometimes a customers dollars aren't worth the trouble they cause. So they either fire you as a customer or hit you hard with the ******* tax
#51
I'm not defending Livernois Motorsports. But on a manual trans 5th gen Camaro, there is no torque management when you turn off the traction control & stability control. The Maximum Torque Rpm vs Gear is at 6042 ft lbs stock, and the Torque Limit vs RPM > Max Torque for 1st through 6th has no effect.
That being said, I had to retune a customer's Livernois Motorsport H/C package on a 2006 GTO. It had a P0106 map code that they said was not tune related and very poor drive ability. The customer tried new map sensors, checked for vacuum leaks etc.
The cause of the P0106 was because of the lower vacuum from the cam, that they didn't disable the P0106 map test (very common when tuning for an aftermarket cam). The WOT AFR was as lean as 16.5! The spark tables, idle speed & High Maf table were all at stock values.
The only things that were changed was the skip shift was disabled, disabled cat tests, lowered the fan temp, and raised the speed limiter.
Russ Kemp
Russ Kemp
#52
Russ Kemp
Russ Kemp
The original thread was showing how to disable TM on a manual transmission car I believe. Here's the link to the original thread
http://www.camaro5.com/forums/showthread.php?t=203433
#55
Because I'm just now finishing my build. Been saving $$$ to have it retuned in the meantime. Doesn't matter if this started 10 years ago, I paid for something and am not getting what I paid for.
#59
if this thread it bothers you so much then why are you here?
#60
oh okay. Yeah that's fine. Fire too many customers and you'll be out of business like Lethal and the others. Seems like that's the road they're going down
